"Triangle" Warning light . . . . . . .
Not open for further replies.
luke scott
Dublin & Andalucia.
The bottom warning light (Triangle under the ABS light) is staying on. I thought it was the brake light but that's working :nenau. There is plenty of brake fluid and the servo is working fine. Any thoughts ?
The bottom warning light (Triangle) is staying on. I thought it was the brake light but that's working :nenau. There is plenty of brake fluid and the servo is working fine. Any thoughts ?
Are you certain the lights are OK. Have you taken the bulb out and physically examined it?
When the tail light fails. The ABS puts the warning light on (triangle) and then uses the brake light as both a tail light and brake light.
:nenau
:nenau
AHA . . . . . I'll get a new bulb in the morning. Thanks Ian.
