Tyre pressure indicators
g.s.john
Getting old aint fer pussies
slade green kent
Are not showing anything on the screen no warning lights or amber triangle
ideas anyone?
07 1200 GS
when batteries died in mine I had an intermittent error message. Went away for about 6 months, with no pressures showing and no error msg. Then error message started appearing again. All sorted with batteries replaced
what makes you think they are fitted?
I expect someone unticked the TPMS using a gadget, as the batteries went flat
If you remove the sensors or let the batteries go flat the system will not show any warnings though there may be errors in the ECU register.
In my case, when the battery died, I had to live with the triangle warning which was very annoying! As above, it was probably disabled in the ECU to turn off said warning.
