I noticed that the handling was a bit wierd at times at the weekend and have just been out again this morning and its even worse. Slight weave in a straight line, left hand turns arn't to bad but right turns are now almost uncontrolable. Then after I had removed some weight and had a quick look I found this problem with the front tyre. Now what do you recon on a replacement, o.e. or given that I figure about 70% of use is off road something along the lines of a TKC. Anybody recomend a suitable tyre or supplier. Oh and what air pressure should I use. Thanks in advance.
