What grease?
Udders
On My Own But Not Alone!
Outside
I've just had my front wheel out for a good clean up and a new tyre etc....
Now the spindle was a bit grotty so I gave it a smooth down with 1200 grit sandpaper and got all the old grease off. Now it's about to go back in I'm wondering if I've got the correct grease for it? :nenau The stuff I was about to use is multi purpose MOLY GREASE for CV joints. The operating temp range says 20 - 135 degrees. Is that the right stuff to use? :nenau
Use it.
As far as I can tell with this bike is that it helps prevent corrosion and doesn't make the wheel rotate any easier. :thumb2
Good grief - I thought I'd wondered into the 1200 section by mistake then :augie
I take it you have nothing sensible to say then.:blast I'm glad you either already know the answer but are too much of a **** to help someone who doesn't OR are one of the lucky ones who can afford to take your bike to a dealer to do the job for you. Nice. Cheers.:thumb2:eek
I use castrol LM grease. As you are just lubricating the spindle and the amount will be minimal then any grease will be better than none. I would be happy using your multipurpose grease,
There is a view that you should not use copperslip type anti seize (PBC etc) as this can damage bearings in the unlikely situation that it finds it way into them. Good job I did not know as I had been using it on my spindles for 30+ years without problems.
:blagblah :blagblah :blagblah
Obviously not the 1200 section - they are much nicer in there when the old oil/grease/tyres questions come up :rolleyes:
Best you toddle off and amuse yourself in there then. :blast
Well udders has the hall marks of a 1200 owner, the lack of tolerance and humour at a flippant remark . :D
I've got a sense of humour alright but not when I need to get my bike back together and you get twattish answers. :blast The Haynes manual says to put a smear of grease on the spindle but not what type of grease! :blast
I'd never lower myself enough to get a 1200! :eek
Thanks to Ditchwater and Warmshed.
Here we go again!Someone asks a pertinent question and after 9 replies he still has not had an answer.Use an all purpose grease, even better if it is a waterproof grease.
Look again, the answer was in post #5:D
Holy shit guys, Take a bloody big chill pill...He only asked a question, Its not like he wanted to steal your wife....
CV grease will do the job just fine..
There you go , It didn't hurt anyone and no one was offended...
Better to ask a question than go and do a job and balls it up...
You will have to try harder next time!!
I presume sir you mean that dahoum person,indeed sir a man of lowly stature and ex moderator for this popular forum.:augie:eek
That's the fellow, also a useful source of information with many matters concerning Lawrence of Arabia and er, um ah well..... I can't actually think of anything else other than him being vertically challenged:thumb
