Underwatergoat
Check this month's (August '04) TWO, there's a feature on why engines DO still require running in.
DEFINITELY dump the synthetic oil right away and put mineral oil in. Since BMW recommend Castrol oils, the one to use for now is GP, followed by GPS (semi-synthetic) once it stops using oil.
If Castrol are telling us to use cheaper stuff, and Mobil say use their expensive stuff, who do you trust?![]()
I used to work for BMW as a bike Tech. This advice is EXACTLY what I would have given about any R 259 (boxer) engine.
I'm sure it's still good advice, but I'm outta the loop now. If your really really bothered ring BMW and see if you can speak to their tech people. I won't put the names here in case I ever want to work for tem again.
I recon It's pretty safe to go GP first 20k miles then GPS forget fully syth. The engine may never stop consuming oil so I wouldn't wait for it to happen. The permissable amount of oil consumption is quite high. I can't remember exactly but something like a litre every 1500KM.
