With the help of Steptoe's howto and the clymer manual, I've just removed the left hand head off my 1100 in order to change a weeping head gasket.
In the process, two exhaust studs sheared (the inboard, 'middle' stud on each side). The other four studs just wound themselves out of the head, so easy to fit the new studs I've bought. I don't fancy digging the broken studs out myself, but there's a good engineering shop locally which can replace them.
But.....
In Steptoe's howto, he says it's quite possible to run an 1100 with one or even two studs broken on each side....
So if it were you, would you just refit the removed head with new gasket and ignore the one broken stud on each side. Or would you get the broken stud replaced on the head which is off the bike and then remove the good, non-leaking head to get that stud changed too?
Opinions gratefully received.
cheers
Matt
But.....
cheers
Matt
