Wheel advice
HGS
Wrexham
Wondered if anyone can give me pointers with the following
I got a slight bend to the outside of the front alloy wheel rim, no paint damage, no air loss and no vibration. Probably caused by pothole but I cannot recall it happening.Tyre fitter pointed it out to me in May this year.
The fact the gloss finish on the rear wheel looks rough after 18 months despite being cleaned the same way with the same products as the front has prompted me to look at having them refurbished as tyres are due a change as well
Locally, there is a very good wheel repair and restorer. Used him before for car wheels and he has given me an excellent price to strip & re-coat both wheels and repair the front one. He will need bare wheels
Can anybody advise about the following:
Are the front wheel bearings easy to remove?
Are the bearings and seals reusable or would they need replacing?
Are the disc bolts / RDC sensor ring bolts reusable?
The RDC pressure sensors - Are they easily removed / refitted ?
Do the RDC sensors need calibrating / coding afterwards?
Hello from across the pond!
You have lots of questions that might be answered by some parts of these 2 videos I made.
Enjoy, hope they help.
Boxflyer
Converting Rims, removing and reinstalling bearings and seals, installing TPMS and speed rings.
https://youtu.be/ZS8eZdVaCGU
Installing and activating TPMS using the GS-911
https://youtu.be/4HAnT58b2DY
Thank you...has answered nearly all my questions regards the removal and fitting
Just need to find out if I use the same RDC sensors on the same bike will they need pairing again?
Much appreciated
If you keep the same location for the Front/Rear, they should be displayed with no difference...just as if the bike was turned off, and then turned back on.
Fingers crossed... thanks
