retiiredgixerbloke
Ok fellow gsers which engine oil would you recommend me to use in my newly aquired R1150 gs i have been pointed in the direction of 20w-50 but thought i would ask the exerienced members on here? thanx in advance
I Love a good oil thread - was wondering when the next one would come along.
I use what ever Steptoe shoves in for the service.
Neil used 20/50 from a big barrel in the corner when he serviced mine. Off-hand I can't remember the brand but did note the grade for future reference.
As already said, "normal" oils are fine as long as you use the correct spec. The engine oil is mainly up to you, I use 10-40 semi synth.
The bit to be careful of is the gearbox and bevel as GL4 is most common and cheap but they spec GL5.
To be honest, BMW have changed their minds several times over the years from 10-40 to 20-50 etc.![]()
