Thankyou!................................which is the bit you need to twiddle![]()
If your lever adjustment is already on 4 and it is not disengaging enough to find neutral, you can also adjust the master cylinder plunger using a small (2 or 3 mm, can't remember which) allen wrench. Loose the cross (locking) screw and then screw the plunger in or out to adjust as needed, then tighten the locking screw again.
did anyone adjust that plunger ?
and the result ?
thanks.
Any news from the OP?![]()
