Wiring diagram
mikeyboy
Overland and classic,vale of belvoir,Melton Mowbra
Hi chaps,can anyone point me in the right direction for an online wiring diagram,specifically the LED fog lamps.
I have aquired a set to fit to my 1100 and would like to check why BMW have 4 wires going into each lamp before I start wiring things up.
Thanks in advance
Mike:thumb
Thanks in advance
Mike:thumb
If it is on a wc bmw, then there is a socket for the led fog lamps behind the front fairing in the left side. You have to remove the fairing to see it. It is placed app. under the left turn signal.
Regards
Thomas
Does nobody have a rep rom for the toilets that can look at the wiring diagram for the man!?
No prob if no one has the reprom,I'll speak to the dealer and get them to email me the relevant diagram.
I'll prob just wire them on the two wires,but was inquisitive as the how BMW had wired them and why
Well, no need to throw yourself under a train about it then :thumb
If you do get to know I would like the same info plz..
Mikey,
Please let us all know the answer when you find it.
Ta.
Hi there,
Did you ever find out this info please? I have the same 4 wire lights and i don't know which to wire up.
thanks
andy
The other two pins are not connected...
