WTF?
Bryn
Moderator
Moderator
South Leicestershire
So now I have mapsource working well on the Mac having used the conversion software...
I can plan a route and send the said route as a GPX file to others, who have successfully opened the route with mapsource on their PC's , and even Tom Tom with the conversion software.
Thing is... when I save the GPX file in my documents, if I try to open it again it doesn't open onto the page you are opening... if you know what I mean...
And when someone else sends me a GPX file I can't seem to open it?
I've also tried to open stuff on here but it downloads into my documents and once again nothing seems to happen..
Am I missing something or is it because I'm using a Mac?
Its not causing me any probs yet as the Croatia 09 trip is being sorted by me so I have the routing to send to others.... If I was on someone elses trip it may be different ;)
Have you tried firing up MapSource from a desktop icon, then File->open. New window opens - make sure that the 'Files of type' option at the bottom of this window has 'all files' selected. Then browse to your file and 'open'.
I'm not a Mac user, so this suggestion is based on the PC version of Mapsource....
when i've tried opening routes in road trip, i find i need to use File>Import in the menu.
actually, i find road trip such a pain, i now run mapsource in windows (ugh!) using vmware fusion :(
weird ETA's with RoadTrip
Bryn, if you plan to use routes generated from RoadTrip for the Croatia trip, you might just try out a route in the UK first. I did 2 routes for a recent trip to Scotland and whilst the route was ok, the ETA's were coming up as 12 to 14 hours for what was only a 5 hour ride. This was the downloaded route into a 2820. Sticking with Mapsource for now using VMware or Parallels.
paul
Thanks for the info chaps...
I'll bear the one in mind about ETA's although the Llangollen ride I did was ok...
I'll have a mess around and see if I can sort the opening stuff :thumb
