Xt sound output
boatman
scotland
Hi folks
I used to run 2 zumo 660s on my bike ( handy if 1 packs in months from home )
One wired to the autocom directly
One connected to the autocom with an autocom BT 02 dongle .
The new zumo Xt which has only blue tooth and No wired connection I have linked into the Autocom via the BT dongle - - it works but it will not provide anything like enough volume to use with ear plugs in .
Anyone had this issue ?
If I cannot resolve it can anyone recommend a good simple ( don’t need mesh etc )reliable and robust helmet com that will deffo provide enough volume to hear music / Nav instructions with foam ear plugs in?
Sena 20S works for me. You can use in-ear speakers too with 3.5mm jack plug
Time for the Autocom to go - it had its day.
Hi folks
I use a 20s Evo, with moulded in ear plugs on my XT & volume is not a problem. Have you checked the 'Mixer' menu in the sound settings to make sure you have the volume set to the correct level for your set up?
Done that thanks
