Zumo deleting waypoints
GrinningGSer
Infamous old git
SW
I borrowed a Zumo this weekend, prior to purchase
Loading waypoints/favourites sorted, but how do you delete them ?
I have tried the RTFM routine but cannot find the info
Easy to do on my Quest, but seems not so easy on Zumo
Also... The zumo has a file, read through the USB connection : /Garmin/GPX/current.gpx
If I delete this file, will it delete all waypoints or will it destroy the Zumo ???
:D
1. Press "Where to?"
2. Press "Favourites"
3. Select which favourite you want to delete
4. Press "Edit ..."
5. Scroll down and select delete
6. Now you can go through your list of favourites and select all the ones you want to delete
7. Press "Delete"
8. Press "Yes"
Done
HTH
Del
Thanks Del
Not as good as my Quest then... no delete all ability. I may average say 20 waypoints on a ride and I do not wish to keep them in the Zumo.. and also do not wish to delete each one by one :blast
I have an inquisitive suspicion that deleting the current.gpx file will delete all waypoints, but I have not dared to try that ... yet
:D
It's not exactly clear when reading my post, but at step 6 you can select multiple waypoints to delete (you can check one, all or selected ones). There isn't a delete all function (that I've found, yet!).
You may be right about the current.gpx. Make a backup copy of the file so that you can replace it if it all goes t*ts up.
Del
