The sockets on my RT will allow 10amp shared for both, so if only using one, then you can get away with gloves and a vest, it wouldn't support a jacket on high and gloves, just check the amps required. You can buy a din socket that allows heated gear to be used with the bike socket. If using gloves and jacket, you will ideally need a dual controller or both gloves and jacket will have to be on the same heat setting.
