Bramble
Sometimes when I pootle along on a constant throttle - say in a long 40 or 50mph speed limit - and I come to change down the engine just turns off!!!!!!!!!!!
Just to be clear - I pull in the clutch, blip the throttle, change gear and NOTHING. It's really scary if I don't whip in the clutch. It's as tho' the engine doesn't "catch" as the throttle's blipped.
The bike will then only start again using the starter. It will not start by easing out the clutch and giving it a bit of gas.
It doesn't seem to matter whether the engine has just warmed up or has been running for hours.
It doesn't happen very often but it's not predictable and it's something I'm not enjoying living with.
Oh, I've got a Remus can on at the moment but it used to do it with the standard BM one too.
Has anybody out there experienced anything similar?
And does anybody have an idea how to cure it?
Is it lean running?
Is it operator error?
Is it lean running?
