Sold 1982 R80g/s “street sleeper”😎
mikeyboy
S.M.T.R. Craigellachi,Banffshire
Toe in the water as it’s not quite finished.
I bought this as a runner with a death rattle from the timing chain.
The short motor has been fully rebuilt with new main bearings,big ends,crank sprocket and full timing chain set.
The barrels/ pistons are 1000cc with new rings,and stainless push rod tubes.
It has big valve 1000 cc heads with hard unleaded exhaust seats,new guides,valves,springs and collets.
Finished off with new “ peanut” covers.
Anything not replaced ,you can rest assured is in very good order.
The carbs are 40mm bings to complement the heads and barrels ,which will give a 40% uplift in power taking it to @70 hp.
The gearbox ,
Complete rebuild with new bearings,camplate spring kit and roller bearing upgrade.
The output shaft has been modified to take a circlip.
It’s also been fitted with a full set of primary helical gears( kerrrrrching).
5th gear is a high ratio,+5%,to take full advantage of the. Extra power.
It’s also a kick start box,though at this time I don’t have a lever.
Forks and brake caliper rebuilt,
To be fitted when the wheels come back.
Along with a new brake line and a new 12mm master cylinder to give the best braking possible from a single discimage.jpg
Any questions,fire away.
Price is £14 k finished as intended,commissioned and motd ready for historic transfer.
I can offer upgrades as required,
Should add,
Every nut and bolt on the bike is stainless.
Newish wiring loom that came of a write off.
Full stainless exhaust.
Seat will be recovered, what colour would sir like it?
Or I can fit a single seat,POA
Looks a cracker , Mike , as are all your bikes, and I should know having sampled the quality of your work.
Much better value than a new non-descript GS piled with electronic gubbins just waiting to go wrong .
Kind comments,thank you👍
I think this bike is going to great.
The power uplift will make it a joy to ride.
As with all of my bikes,I build them the way I’d build a “keeper,”
