Airhead timing strobe, recommendations
Not open for further replies.
kirby morgan
West Kilbride North Ayrshire
Looking for some advice guys.
I've got a 1979 R65 which I've got going after many years lying in a garage.
changed the points, set the timing statically, but would rather , set it using a timing light/strobe.
Is there a recommended strobe for use on the 2 cylinder airheads as I see some timing lights are for car use only.
I've been browsing ebay and there's loads of older ones for sale, but unsure whether to buy as there seems to be common faults/repairs required ( inductive pick ups going wrong)
Anyway, if someone can give me a recommendation for a suitable timing strobe, compatible with the airhead, I'd be obliged.
You should be ok with any strobe use a slave battery and you should be good,I bought one from amazone
