Another muppet question
Mikey
well just a little twisted
Away with the fairies
I've got my Garmin mount and after reading the previous threads I think I need a RAM-B-202, a RAM-B-201 and a RAM-B-231 to attach it to my handlebars. Is this right?
Bring it on, Mikey ...
This combination is used to hold the Garmin Quest bike mount kit ??.
The RAM parts; "RAM-B-202, a RAM-B-201 and a RAM-B-231Z" had been suggested to hold the Garmin Quest bike mount kit as the Garmin instruction leaflet shows four holes from the AMPS hole pattern on the bike bracket.
There's an option and a choice. Its the difference of two hole fixing (use RAM-B-238) or four hole fixing (use RAM-B-202).
If you use the two hole fixing option, then go for a RAM-B-149Z as it contains three parts; RAM-B-238, a RAM-B-201 and a RAM-B-231Z ( Z = zinc U-bolt). However, if you prefer stainless steel U-bolt, order then the mount is RAM-B-149.
RAM-man
RAM-man
Sorry should have said yes it's a Quest bike mount kit. I'll think I'll go for the four hole fixing.
Mike
