I’ve not long bought my new (to me) 2006 R1200GS and it’s already causing me sleepless night, the centre stand and the rider footpegs were so badly rusted I have taken them to be blasted and powder coated. When the stand comes back I need to replace the pushrod seal. The timing cover is badly pitted, not leaking though, and I am waiting the arrival of some weld –it to fill in the holes before painting.
But the thing that has peed me off the most is the exhaust, I took it off to refurbish the timing cover and in the process broke two of the studs on one side, the studs on the other side were already snapped but some bright spark had glued the nuts back on with epoxy &*@@&&.
I have managed to extract one of the broken studs but the other three are still in there with about 10 mm showing on each of them, apart from removing the heads and taking them to an engineering shop, believe it or not is a very scarce commodity here in Aberdeen if you know of one that can do the work please let me know, how best do I tackle this job?
Any help appreciated.
