beakmeister
Tried to remove grub screw from inside clutch bleed holder thing, but is incredibly tight,
fit hex drive bit to 1/4 drive ratchet,
hold clutch bleed holder thingy with Mole grips,
apply a little pressure and hex bit rotates within grub screw,
. I will probably unscrew the whole thing off the hose and drill it out, should'nt be too dificult as the grubscrew appears to be made of lead
Anyone else had this happen and what did you do???
