- Joined
- Aug 3, 2009
- Messages
- 3,034
- Reaction score
- 402
Couple more bits done today. First I finished off the exhaust as the tail need to be welded on in the right position.
The old torsion bar for the final drive was 60mm too short. I cut the old one in half, drilled and threaded both ends so i could use a long threaded bar up the centre. I then made an aluminium sleve to go over the bar and tigged up both ends. Back on the milling machine I took it back to its original 20mm outer diameter.
Came out a treat
Wiring loom sorted out and re wrapped.
Headlight, tail light and rear indicators all wired up.
Came out a treat
