By Jove ….I think I have made progress
JohnnyBoxer
North Yorkshire
Last weekend I thought I would try Garmin Explore app and create a route (track) on my iPhone
I did a simple 55 mile route from home, in a loop and back again - fairly straightforward & on roads I know well
From A roads to D roads (gated & with grass/gravel up the middle)
I just went dot to dot on my iPhone, with Explore
Easy & quite like Mapsource in fact
I saved it in Explore & named it
Then synched Explore with Drive to export the track (soon to be a route)
Drive then Bluetoothed it to the Zumo XT & there it was….a named track
Tonight I went out on the bike to ride it
Found it in the Tracks section & then set it to Go/Start
It displayed it as a track ….D’oh, without directions going forward …..at the next junction etc
Pulled over and tried to activate it as route…it’s in Apps
I could then convert it from a track to a route …bingo we’re in business
Start the route and away we go
Followed the route perfectly without drama & no glitches
Once I missed a turning and had do a U turn & it went haywire, so stopped the route & closed it, then reopened the route & started again from the closest point
Baby steps
What’s wrong with Explore ?
Nice view of Bilsdale on North Yorkshire Moors
Tip top! Welcome to the 21st century, JB. (y)
You have discovered that a modern Garmin GPS device is very good, enhanced as it has Bluetooth transfer, removing the need to connect the device to a computer. That you’ve also discovered that it can convert a track into a route easily, is just a bonus.
I have no idea why the XT went haywire, when you missed a turning and made a U-turn. I can though guess that you had the device set to ‘Automatic off-route recalculation’. Great that the device sorted itself out when you helped it by stopping the route, then rejoining it at the closest entry point.
I have never used Garmin Explore, so I cannot say if it is good or bad. It does get bad press. But hey, so does BaseCamp, which I find very good. Now try doing the same in MyRoute and see how you get on.
PS Yup, whilst navigable, tracks have no turn instructions in them.
Yep I am used to Tracks as off-road we use them and of course aren’t turn by turn, but are quite easy to follow
On the road turn by turn is advantageous
I might now persevere
