Canbus problem?
Mark_S
Wiltshire
Hi Guys,
An apology if this has been aired many times before. But, I am having a problem with the Canbus, my original Zumo 550 was powered by the headstock Canbus via a TT lockable mount & it worked fine. I had to have my original 550 replaced by Garmin because it would not power up at all. My refurbished 550 works fine on the car mount, and when it is connected via the USB to my PC, but when I put it on the TT bike mount it powers down. I have tried the following:
1. I fitted the 550 to the bike mount, turned the bike ignition on & the 550 powers up.
2. When I start the bike, almost immediately the canbus cuts the power to 550, the 550 either shuts down in 30 seconds or can be selected to run on battery power.
3. Alternatively, I start the 550 allow it to ‘stabilise’ (enter the code etc) then turn the bike ignition on, the 550’s display goes brighter (prolly due to canbus power), when I start the bike, almost immediately the 550 loses canbus power.
I don’t think this is anything to do with the 550, but it is a mystery why the canbus now rejects the 550. I checked the voltage and have approx 12V dc on both the bike and car mounts.
Has anyone had the same problem?
:confused:
I don’t really want to hardwire the TT mount with inline fuse to the battery.
All help gratefully received.
Mark
I had a similar trouble with mine
Its just my opinion before anyone says its crap but it worked for me :P
The Canbus has got it confused with the Zumo and switching it off. Switch of ignition and remove key (and leave for 5 mins)
Remove battery from Zumo and replace 30 seconds later. With the Garmin off place in cradle Turn on ignition
Garmin should switch on with ignition then start the bike & go for a ride
come home switch off ignition 30 seconds later it should say "power lost continue on Battey" "yes or no"
Should be sorted :) if not rebot the Garmin from the computer to see if this helps
If that dosnt help its feked
Jim:thumb
