Centre stand rattle
Spike
Guernsey Channel Islands
Every time I go over a sharp bump the bloody center stand rattles like hell, does not do it all the time it just depends on the bump.
Not really bothered me until today, went round a small roundabout and hit a pot hole and the bloody stand hit the deck, nearly sh*t myself.
Anyone else had this problem??
Would a new set of springs cure this rattling???
or is there something else I could try ??
spike
That does rather sound as if the springs are tired - or maybe one of them is broken/missing. Another possibility is that the rubber bump-stop might have gone AWOL. That would cause rattling and would also allow the stand to flap around a bit more, possibly resulting in it hitting the ground as you describe.
I am here: http://tapatalk.com/map.php?4z0cnk
You could perhaps give it a waggle and see whats loose. That would point you in the direction of a solution.
Had one of my centre stand bolts sheared in half over the winter... could be worth a look at... M10 C/S 25mm lg...
I am here: http://tapatalk.com/map.php?4z0cnk[/QUOTE
Thanks for that, will take a look
You could perhaps give it a waggle and see whats loose. That would point you in the direction of a solution.[/QUOTE
I could not get the same noise by doing that, but will look into it more closely
Have you lost the rubber "bumper thingy"?
Will take a look
Will check on that too.
Thanks for all the pointers guys will let you know
spike
Not sure if it's the same with the 1200s, but on the 1150's the ABS setting/resetting itself (over bumps) used to make a clanking noise which some riders were convinced came from a loose centrestand.
Just a thought.............:thumb
Thanks for the input but this happens with out the brakes being applied aswell.
I have not had a chance to have a look yet as been laid up with some sort of bug.
spike
