beermonster
My bike is still off the road some five weeks after the last breakdown. The problem is that the injectors are not shutting off. Electrics are not my bag so handed bike over to an independent.
I am told that all the sensors check out, the bike has been subjected to electronic diagnostics and no fault codes picked up. On top of that crank sensor, injectors, TPS and ECU has been swapped to no avail.
The bike has let me down previously a couple of weeks prior to this latest problem and the fault lay with the fuel pressure regulator valve, which was replaced. Fuel pressure now also checks out.
My guy seems to think the problem is in the loom, the injector circuit checks out so it ain’t there either. Anyone by chance come across this problem or have any suggestions?
There seems to be no end to this.
