2000DXP
Hello, hope you are well.
I have a 09 R 1200 GS which I have fitted the full compliment of BMW Vario hard luggage, top box and panniers.
I use the ESA settings quite a lolt while solo and two up but one thing I am not sure on is what setting I should use for Solo use with empty panniers.
I leave the luggage on always and I usually set it as Solo without luggage. But could I do any damage to the suspension if not set correctly to cope with the weight. Should I be setting the suspension to solo with luggage instead, even if it is empty as the empty hard luggage adds up to a few Kg.
Thanks in advance
Dave
Thanks in advance
Dave
