Ever had this?
FFS just undo the speedo cable at the wheel, tuck it out of the way and see if the noise disappears.
If it still makes the noise it'll be the speedo drive. If all is quiet it's the cable.
They Don't call Him "Steptoe the Diplomat" fer Nuthin! :aidan :aidan :aidan
In fact Diplomatic and Steptoe ??? Are they allowed in the same sentance
That was my next suggestion but was gonna leave it fer Friday :aidan :aidan
Not annoying, i just despair at the lack of common sense and the waste of bandwidth. :D
Another typical response by Mr. Steptoe.
Is it not the purpose of this site to help each other out & share experiences.
It's only easy if you know the answer, if you don't know the answer then would'nt you ask the audience
:nenau
:nenau
But I gave the answer :blast - it's the reply that i was responding to. :D:D
Yes but starting your answer with FFS sets the tone,:spitfire
I wouldn't let anyone start a conversation with me with FFS. so why should i on here. But its easy from the safety of distance; :rolleyes:
Its common good manners is it not? it costs nothing to be decent :rob
So,
I have asked for assistance, i got great answers to my question with different results. ( thank you all) As i said i WILL check everything i have been told.
I know that some of these will be not related to the problem, but not knowing all, as you seem to from your wealth of experiance, i will check out anyway.
EG. the alt belt, Thanks Aidan :thumb2
But to keep a bit of light hearted banter in the forum (see Mandy's thread about craic) I asked all to keep them coming and started to give odds on the solution. Just for a bit of fun. As you will see your solution given by another tosser is favourite at 2:1 so one would assume that i have got the message. But as i said if it annoys, or frustrates you then please ignore. Thank you.
My kindest and deepest regards.
Ron
:aidan
And the above two posts show how the forum has evolved over the 4 years between Steptoe joing and Falcoron doing the same.
FFS Steptoe, evolve or piss off. (But please dont piss off because I need access to your expertise - and expect to be berated by my frustrated betters).
And dont worry about taking flack, I am reliving Feb 2007 (http://www.ukgser.com/forums/showthread.php?p=897475#post897475), had the other foot done, so am laid up for the next few weeks with nothing better to do than to stalk this forum once more, so I shall no doubt act as chaff.
Hey Guys lets all take a step back here, CHill for a minute and have a cup of tea or summat!
Ron I understand exactly what you are saying, I don't believe Steppers was intentionally being Nasty, it was more of a "try this and you'll know " sort of an exasperated sort of a mini explosion, rant sort of thing!
Neil "Perhap"s the FFS wasn't just the best of ways that you could have started that sentance.
But I think understand your sentiment "Exasperation" because you can feel it in your water but you can't touch it and sort it from way down there. And no one else seems to have a grasp on the handle.
I feel the same way with Mr "I fell off my Boxer on Boxing day" on the BMW club we're both pretty damn sure what it is but we can't just get it across?
Exasperation The New Word for today :aidan :aidan
If I'm muddying the waters "Well!, Pardon Me!" but I was only trying to Help! :aidan :aidan
Hi Jay,
Not bothered one way or tuther mate, if anyone is exasperated by my question then i appoligise, but why bother answering it? I read most posts as i'm sure we all do and if it interests me or i can add something to the thread in the way of help or encouragment i will. If not i won't, simple. what i will not do is get nasty, or rude to someone just because he or she dosent know the answer right away. If we all knew as much as some it would be a quite forum now wouldn't it? And we wouldn't need a moderator. As far as im aware this section of the forum is for technical questions and then those in the know can answer IF they wish. All im saying is if its so annoying then don't do it or if you must then why be nasty?
Thank you ever so much old chap, i value your opinion and take on board your comments.
My kindest most sincere regards.
Ron
If I can just interrupt the "banter" for a moment, I still fancy the alternator belt as the culprit, if it is the symptoms should become worse with extra electrical load, try testing it with and then without lights/heated grips etc.
Stewart
Hi falcoron,
In case it is the speedo cable, would it be a good idea spraying WD40 or even oil into the cable? It could just be dry.
The other thing you could check, is to make sure the speed cable goes straight from the speedometer down to the wheel.
I also replaced mine one month ago and paid attention to these details.
Hope this helps and good luck!
Ahhh....but FFS ..... didn't I read that you still had the howling when you pulled up for a moment .....in which case....FFS the speedo cable FFS will have stopped whizzing around.... therefore my diagnosis is you conincidentally have not one problem but two FFS :augie alternator poly V-belt is a good start for the noise and the speedo cable for the speedo with a mind of it's own FFS QED 2 problems concealing each other and confusing the diagnosis..... where do I collect my medal ? :P
One is becoming Suspicious that there May and I can't be absolutely positive about this BUT there May just be a certain amount of sarcasm creeping into this query :aidan :aidan :aidan
Stewart
Thanks Stewart,
It will be checked and replace as soon as i can get away from work. Its probably worth doing anyway with this milage. Bye the way this is the 7:2 second favorite :thumb
Not so FF ( fleetingly fast) Geko me old son, I will need to check both first FFS (fault finding session:green gri)
I am going to undo the speedo tonight and i will report tomorrow if its been FFS ( fixed for sure :mmmm )
So i'm not paying out just yet or giving medals (FFS, false falice symbols)
Please be paitient
but thank you ever so much for your kind and helpful advice.
Regards
Ron :beerjug:
Noises (bike not forum)
I think that is the answer, thers two probs alternator belt, fan belts in cars make a hell of a racket. Don't oil the cable as it will work it's way into the the speedo head and all will be fffs. Speedos are not robust and so if it made that noise it would stop at once, of course if you have Manderine coloured gs, the speedo is probably registering correctly as we know these are the fastest gs's around. any other colour and the speedo's knackard.
dave (manderine ) GS (ffs).
LOL! see what you did there, like it. very good:thumb2
Think this is now odds on favorite and speedo alone is not liking the going as much, so falling back a little on the tote. :cool
nearly time for the start though so wait for it! wait for it! :bounce1:bounce1
FFS Steptoe, evolve or piss off. .
it shows something- It shows how everyone is so ssooooooo serious.
FFS - Think about it. Think of the persons initial who needs help.
For falcorons sake !!!!!!!
. I did wonder, but i forgot how PC and inward looking everyone is nowdays. Cookson i can understand, he's always a bit slow in thought, but quick to jump the gun :rob
Now tell me ( i do find it funny when people get wound up over things) , why should i change just because your fecked off ?? How does that work. :rolleyes:
