What's up with yours? I've used one of these for 10 years. 2 1200GS', 1 1250GS and now a 1250RS and it's worked just fine though I have had to change the rubber pad. It was a bit critical on the GS' where the stand was positioned on the pad to avoid the centre stand catching the wheels when moving it about and when trying to put it on the stand, but I put an alignment mark with a sharpie on the paint work to help get mine in the right place.I bought one of these for the garage to turn the GS around and it won't take the weight of GS repeatably as the centre stand has to be off centre to allow the centre stand lever to have clearance.
Can you recommend a turn table mechanism more suitable to the GS?
My shed dia. is 10ft x 12ft plenty room to turn around in.This one looks way better than the cheapy I got, as the centre stand weight is shared evenly. When I use mine the is a huge gap difference comparing either side thus feel it won't last as it's loading up one side consistently.What's up with yours? I've used one of these for 10 years. 2 1200GS', 1 1250GS and now a 1250RS and it's worked just fine though I have had to change the rubber pad. It was a bit critical on the GS' where the stand was positioned on the pad to avoid the centre stand catching the wheels when moving it about and when trying to put it on the stand, but I put an alignment mark with a sharpie on the paint work to help get mine in the right place.
Dolly park-n-move MS compatible with BMW R 1250 GS / Adventure ✓ Buy now! https://share.google/zmqqYmU35kQsJDj1R
I have the same thing. It works…This is what I bought, had now for over a year, made the mistake of putting bike stand down on metal base plate, Metal on Metal, can cause slippages, which surely did in my case.
Hence now have a thick rubber car mat cut to shape glued firmly over it, No more slips n spills.
It works best when it's level with floor, in my shed I needed a cleaner floor and put down 2 x 8ft x 4ft sheets of 3/4" inch ply, cut a hole large enough to fit turntable into.
All I have to do is position front of rear wheel 1" inch from Turntable then lower stand and lift up, easy on my r1200GSa to rotate, apply body weight slightly to back of bike and turn.
Just remembering it's always there, and not step on it, or its back to disco dancing technique trying to maintain balance and graceful equilibrium.My shed dia. is 10ft x 12ft plenty room to turn around in.
Loading…
www.motorworks.co.uk
Buy cheap, buy twiceThis one looks way better than the cheapy I got, as the centre stand weight is shared evenly. When I use mine the is a huge gap difference comparing either side thus feel it won't last as it's loading up one side consistently.
Should of read your post before I replied again.Linked to the same dolly as mine,great bit of kit for the job.Buy cheap, buy twice
They also do one with brakes on the wheels, rather then the bar and block that you move through 180 degrees to lock/unlock the stand, which can catch on the centre stand extension when you're locking the stand in place before you get the bike off it if you're not accurate with how you position it when putting the bike on it.
Dolly Mover for Centre Stand ConStands Mover II, max. 320 kg, red ✓ Buy now! https://share.google/QzVQiOoNjzSJIO4aR
They are well made, the wheelson all of them have a rubber compound tyre, rather than hard plastic so move across small irregularities etc on the garage floor better.
