Garmin 2720
Smudge
Kent
Been searching this forum but can't find the info. required. I am sure someone can help though. :D
Can I upgrade my Streetpilot 2720 to give more memory for routes and maps?
Hope someone can help
:beerjug: Smudge
No you cannot increase the memory on the 2720. What extra maps do you want to put on?
Thanks illustrated .. I want to put maps for a trip taking in France, Germany ,Austria, Slovenia, Croatia, (Montenegro, Albania), Greece and Italy,.
I think if I have a rough idea of the route I will get most of the maps I need .. I hope !!!!! :augie
2720
What map version is currently on the unit? i have a 2720 with v2008 map and it covers all the countries you list, and i had v6 on before which also covered the same but with less detail in parts.
Unless you have an import (with mapping for another region preinstalled) then, as illustratedman says, you have the memory available for this and should already have the mapping for those regions on the unit.
Even if your 2720 is imported from outside Europe then you should have enough spare memory to fit mapping, routes and custom POIs, should you need them, for your trip. I have an American market 2720 with North America v7 installed and I still have space left over for more than half of Europe as well as all the routes and POIs I might ever want to load. I could fit the countries, in their entirety, you mention as well as the UK and still have space to spare. You shouldn't need all of the countries you mention, just the map tiles for where you'll be going.
Instead of having all of Europe preloaded as I would if my 2720 were a European model, I have to load mapping as I require it although the chunk of Europe I have on there already is more than sufficient for my needs right now. If I need to go outside the area I do have installed it's just a case of selecting the areas I do want in Mapsource, hook up the GPS and then use the send to device button. This will overwrite my existing European mapping but not touch the preinstalled US mapping (more's the pity).
Thanks Gents,
I feel a lot happier now :D.
I have V.9 europe installed on my unit so I guess I was worried unduly :blast
Anyway thanks for your help and :beerjug:
