- Joined
- Jan 3, 2002
- Messages
- 1,483
- Reaction score
- 4
I will be investigating, but to maybe speed things up....
I've noticed I have noice green lubricant running down back plate of gearbox, appears to be coming from top of box where airbox assembly mounts.
I'm guessing perhaps the little retaining nut for the airbox cover has come undone of something similar.
If not, any other thoughts?
I seem to recall that there is a breather in there (not engine one into carb inlets) or maybe I'm confusding the one on speedo drive.
Anyway I will have to take carbs and whatnot off - but any clues and anything else it might be could save me some time.
I put a rebuilt box on around 6,000 miles ago - hence thought maybe nuts come lose on top.
Many thanks Fritz
Many thanks Fritz
). The oil from the breather shouldn't get into the airbox unless the various plastic pipes and rubber junctions have come apart.
the one that holds airbox assembly to gearbox.
hopefully have a neb at w/e
