Going Rate ?
Stirlingmoz
Woking, Surrey
What do you think the going rate is for a Monolever bottom end with unknown history these days ?
Trying to do a deal on this lump. Comes with engine covers but nothing else.
eBay pricing suggest £200-£400 dependent on condition and completeness
I'd be looking to do a private deal under well under that pricing
I’m hoping to be around £200 or so for the bottom end as pictured plus starter motor, diode board, engine covers and the cylinder studs.
The story is, it was bought as a spare and has been in his garage for years - original bike long gone. He’s clearing the garage pending a house move.
I’m haggling hard but the deal’s not done yet
Keep haggling Pete…. You’ll get it
Deal done
Could resist a little strippage after work.
Engine covers off
Breather covers off
Oil pump cover off
Lifters removed
It looks ok inside but absolutely filthy from sitting uncovered under a workbench
The clean up and refurb began in earnest today.
The oil filter tube is the long type fitted with oil coolers and needed to be removed.
What an absolute mission to get it out - likely Loctited in at the factory ?
I used heat and a drag link socket with the windy gun turned up to max
The end of the filter tube got damaged during removal but it’s off !
Lots of parts degreasing and cleaning.
Oil pump and housing looks good and measured up well within spec.
The engine is going to have to be completely stripped to clean the inside of the crankcase.
It’s filthy in there.
Just an hour this morning got the cam out.
Before
And after
And the breathers under the starter motor cover
And after
Just the crank to remove now - so I can clean the crankcase inside and out.
Job for another day though
The engine is now fully stripped and ready for cleaning
Just to give you a flavour of the grime inside..
Crankshaft was covered in filth that fortunately just wiped off
Cleaned the crankcase today.
For contrast to earlier photos..
It’s cleaned up quite nicely after a wire brush and jet wash treatment.
Initial dry with an air line then a warm in the sun to finish it off.
Bit more work today.
Put a new short oil filter guide tube in..
(Won’t be using an oil cooler)
Followed by crankshaft and camshaft which had been cooling off in the freezer..
Oil pump installed. Packed with a good dose of assembley lube and learning from a previous mistake,100% sure I used the correct ‘O’ ring this time. New rear main seal installed..
And finally, fitted the flywheel with new mounting bolts..
That’s it for this week.
Little bit of progress on this engine.
New timing chain etc fitted
Covers refitted..
You can just about make out the sump under the engine, which will hopefully go on this weekend (after cleaning) I’ve gone for a G/S style shallow sump with the mounting points for a bash plate. (Oil pick up and dip stick to match)
I think the engine covers are too cosmetically shabby to use.
I’m going to send them away for powder coating.
I’ve still got a starter motor and alternator to clean and refurb to keep me busy.
I’ll have another look to check 👍
I took the fitment advice from Steve Scrimingers book which if I recall correctly says something along the lines of - the guide should slightly deflect the chain to stop it whipping.
It’s an easy tweak at the moment 😉
