Indicator not working?
47Steve
North East, next to the Rusty Angel
My front LHS LED Indicator has stopped working. (GSA1200 2012) It was playing up over the last few months and has now stopped working. I purchased a second hand one of ebay but that does not work either.
I have tried a multi meter on the connection end and it is shown it has power. Do you think I have purchased a dud or could this be something else?
Anyone have any clues before I purchase a new indicator?
TA Steve
I have swapped the front indicators around and they are working ok on the other side. This seems to be telling me that the problem lies elsewhere, possibly in the loom or flasher unit.
Anyone had similar issues or could point me in the right direction of what to check?
TA Steve
There is not a flasher unit as in the old style.
Each indicator is directly wired back to the ZFE ( central electronics unit).
Front left turn signal to pin 49.
all the grounds (brown wires) share a common ground which is not through the ZFE..
Have you tried operating the hazards?
does the indicator light?
if they all light up, the problem may be in the switch cluster
if one is still missing the problem more than likely lies elsewhere
After trying various options I have found the cause. It was a broken Brown wire about 15cm from the conn:thumbector. I have soldered it back together and now all working.
Thanks for the replies
i have a similar problem, in that the right side bulb indicators do work, and neither of the left ones do. It is not the bulbs.
Any ideas?
