Indicators!
ELIMINATOR
Hampshire.
Hmm, riding in this morning I became aware that the left indicator was switching itself on. Pressing the cancel switch once did not cancel them! It took several presses of the cancel switch:confused:
I'll be unscrewing the Left hand switchgear tonight and having a look................ unless of course, it does not happen tonight.
Anyone else had this happen? I do have muffs fitted and an Autoswitch, if that makes any difference.
Switch failure - I think you'll find this is a fairly common problem, mine went in 2003 IIRC. You can either replace the switch (do a search here for where to get them) or replace the entire unit (I got mine replaced under warranty) - you should be able to source one from Motorworks...
Mike
Most odd, no problems on the way home tonight. No doubt it will rear its ugly head again shortly!
