Injector Location?
g00ner
Quite a long way from the top
Bike won't start, was running fine but went out to turn her over having stood a while (month?) and there's no chance of her starting. New battery, healthy spark at the plug, fuel pump priming well, fuel feeds to throttle body when ignition is cycled. Only thing I can think is the injector has thrown a hissy fit while stood doing nothing. Problem is I can't see what is the injector nor how to remove it
Any advice gratefully received :hammer
Was the plug dry when you checked the spark?
Maybe a quick squirt of Easystart will prove if it is fuel related or not.
Pretty conclusive to be fuel related.
Petrol would usually stand for a month with no problem but does go off, the smaller the volume the quicker it seems to decay.
I would get as much out of the tank that you can and fill with Shell posh petrol and give it another go.
