K1200RS hellish fuel consumption
(RIP) Bin Ridin
Dublin mostly!
Hi,
I have a pal here riding a K1200RS ('04) which last time we were out seemed to use a tankful of petrol when normally a half tank would do. no external leaks, and no real bad smell of rich running as far as I could tell. The consumption seemed actual, not just the level gauge.
Any clues where to start looking for the problem?
Bin
You could try disconnecting the Lamda Probe
To see if its screwed up?
K1200RS usually run VERY lean
Is the tail pipe White or Black?.... again usually light biscuit(tan) to white
Hi,
Bin
Yup I've been tinkering and suddenly thought about the Temp sensor too
But you need a GS 911 or diagnostics to do a read of the live data
I don;t think the K1200 has the sensor in the manifold any more I think they have either one or two coolants sensors plus an oil pressure switch down at the water pump
But someone with more recent knowledge would be better to confirm
When my 2004 K1200rs mpg deteriorated there was a hole in the exhaust and I also changed the lambda sensor following advise from the forum
Keith
When a cylinder misfires the unused oxygen makes the O2 sensor signal the engine is running weak so the mixture gets richened (enriched?) aggravating the fuel consumption issue.
Ahhhhh Coolant temp sensor Lucky you asked me for pics Laurence! That's it there on the rear of the cylinder head Gearshift side
I don't think the Lamda goes into the big Leccy box but is just outside it on teh right side but I am sure you have to take the tank off to get at it. Simplest way is to get the right side bodywork off and follow the cable just in case its not too far in :aidan
Original pics were in reference to this LINKY
Here's a couple of pics of LT's that I had the Deep joy to work on
well!
I stuck the gs911 on the k1200RS, and could see the Oxygen sensor going from 140mv to 900mv and in between, switching quickly, maybe 2 / sec. I think this tells me the sensor is ok.
The engine temperature sensor was reading 100C, with the bike idling. Fan running etc. all seemed to be in order.
The bike owner is not very analytical so getting clear consumption figures not the easiest. I want him to get the air filter renewed before going further.
Thanks,
Bin
Laurence Did you ever get a result on this one ??
P.S. I think the Lamda values are 200mv ~600mv but the dealership was a looooong way back now
well!
Thanks,
Bin
A working Lambda with a misfiring coil will give poor consumption. Check all sparks are firing as they should.
