Lumpy Tickover
Santa-2512
Omnipotent one
North Pole
So went to start the bike this morning and all i can describe it as was a lumpy tickover
Normally its a nice purr from the bike and it hovers around 1100 rpm, a fast idle before settling down to the 1k mark
This morning it was on the 1K mark and sounded odd missing but not missing if that makes sense
Almost like one plug out of the four not firing ( a lower plug as opposed to the main plug ) if that makes sense
once under load and running all seemed well but the odd stutter coming of idle rpm to load throttle until warm
No issues starting it up to come home 1100k rpm , bar the odd feeling coming off idle to load (engine not fully warm)
Any ideas?
I can get some stick coils later this week , so i have that as backup and i can reset the steppers as well
Any other ideas
Any ideas?
Any other ideas
Has the weather got colder down your way all of a sudden ??
Only thing I would think about is is your tank drain actually draining to outside the tanks and not spilling inside?
in Which case Bung some of this in and try it for a day or so ?
Yes and no, i have noticed it being lumpy when cold
But today was about 10c and raining
This is just a thought, but when did you last look at the plugs? In my case. For some reason, the bike really seems to get through plugs. Just wondering if yours are old and heavily worn, then this might suddenly load the system and show itself at times like this (cold weather).
Sure. Coils are another obvious port of call...
Interested in the Doc's ideas though!
Can you elaborate on this. I'm really curious. But I don't think I've understood!
So will be here Weds, handy i'm going to be in the car that day ; thumb
What ratio did / do you use i think a whole bottle may be overkill lol
Plugs were replaced at the last service if i recall or the one before
But how many miles between services? I have a rough idea the plugs are only good for about 7-8k miles before the wear becomes visible - that's approx my year's commute to Italy. Hence I have that rough time span
If you lift your Filler cap you will see a dished plate in below
and a hole to the left side
That is "supposed" to drain water to the outside of the tank
Buts they made it a stupidly small pipe prone to blockage
So the water lies there and evetually overcomes the seal and enters the fuel tank
OR the unwitting rider dismounts and opens the lid and water runs in to the tank
May I present Exhibit A of a "Can you get it running for me again?"
My response at this stage was "FUCK Me what have I let myself in for!"
So this mornings startup was fine, smooth tickover at 1.1k
Slightly loud on overrun (zorst flap stuck again i guess)
So just in case 4 new coils , plugs , & an FPC ordered
Dont think mines that bad lol
Think it is water in the fuel
New coils , plugs & a FPC ordered JIC
Cough cough Please refer to post 2
you would haev saved a bloody fortune if you had tried that first and it was the right diagnosis
But........ Cause .......... Effect ........... Resolution
How did it get in there
We know what happens when it ties to run on it
How you going to stop it getting in there ?
Be careful you may just blow the internal hose off if you just go blowing high pressure air through it to clear it !
One of the last ones I did I soldered a length of cunifer 3/16 brake line in place of the steel spiral and gently countersunk the top at the dished groove
