Titto
For those of you with issues finding neutral please try the following, I've been out testing all morning and have gone from having NO neutral to getting it 100% of the time - and it's unbelievably simple to sort.
This was mentioned on the 1000+ posts thread on here re the clanks/crunches/cant find neutral thread too http://www.ukgser.com/forums/showthread.php?337687-Clacks-Crunches-or-cant-get-Neutral.
I have already had the warranty fix for the clutch with the longer thrust pin, but since then the bike was worse. The dealer moved the clutch lever dial to number 1 and told me to see how I go for a few hundred miles etc.
I have now moved the dial to number 4 and the issue of a missing neutral has vanished.
Also, the 'lurch' forward from a standstill into 1st has been massively reduced - more of a shoulder shrug now rather than a violent forward motion!
Lastly, gearchanging has drastically been improved, going up and down. Mine was really bad for 'meshing' between the gears up or down it didnt matter.
PLEASE PLEASE try the following and report back; maybe in this style:-
Clutch dial no:-
(1) Horrendous gear changes - impossible neutral.
(2) No improvement on (1)
(3) Better gearchanges, find neutral more often than not.
(4) 100% Neutral, better gear changes.
Hope this helps some of you with, what for me has been the most off putting thing about my bike.
Now go and test!!!
Clutch dial no:-
Now go and test!!!
