. It’s not progressing as fast as I’d like due to work getting in the way, but there’s no real rush. All the cables arrived from Venhill on Friday so that’s probably the next job before tackling the electrics
That’s defo starting to look like my bike. Nice job, be good to see when it’s complete.Sure is looking lovely!
Mikey you’re a superstar thanksNo photos but,
The main loom runs down the left of the frame rail,with the electrical connectors looping under it to the components.
The rear light harness connector should sit about level with the l/h subframe fixing.
The front of the main loom exits through the front of the frame and passes under the lower yoke,between the front mudguard fixings into the headlamp binnacle.
The handle bar switch gear wiring passes down behind the handle bars,through the headstock triangulation,along the top tube where the electrical connectors fit into the metal bracket on the front R/h.
The clutch and front brake light switch wiring follows the switch gear wiring.
The relays fit into the bracket on the R/h rear with the wiring also looping under from the left.
HTH
