Positive battery terminal
JayGee
Midlands
I am planning to wire an extra two auxiliary sockets on my 2014 GS and use them to power heated vest for rider and pillion. I've always thought heated clothing was for wimps but after acquired a heated vest from a friend and tried it over the winter I am now a convert!
I am going to wire the sockets straight to the battery with suitable fuses. Access to the negative or ground terminal is easy but the positive battery terminal is not easy to reach so I was going to use the positive terminal on the right hand side of the bike next to the battery. This is where the manual says to attach jump leads. I'm sure this will be ok to use but am wondering why this positive terminal is there as it seems not to be connected to anything but the battery, in fact it is just screwed into a plastic bracket, is it there just for jump leads? Or have I missed a connection somewhere?
It sounds like it's for jump leads in the same way BMW cars have a large positive terminal under their bonnets for this. It won't do any harm connecting to it so long as the fuse in the cable you connect to it is close to the connection and the non fused piece of the cable is very unlikely to be able to short circuit to earth.
The terminal is for jump starting but also ideal to pull power from. Best to run fused with a suitable waterproof relay - take the switch wire from the rear tail light feed, this is how most on here add accessories as you cannot accidently leave anything powered up when the ignition is not on
