I have a Quest mounted with a Q-pac which does not now power the unit when it is fitted together, its a few years old.
I have plugged the Quest car mount into the bike and carried out back to back tests on the multimeter and the readings for voltage and continuity are the same. If I fit the Quest into the car mount it works OK but fit it into the Q-pac and nothing. I have checked that the pins are lining up and making contact with the Quest unit and again they are.
The easy option now is to buy another Q-pac to hopefully solve the problem as the Quest itself seems to be ok.
Before I do this I thought I would just ask the collective incase I have missed any obvious problem.
