Quick fix
Paul C.
Grantham
After dropping my bike am still waiting for a new screen mount pin for the left hand side, has anyone got a quick fix till the new part arrives? Have tried to glue it with no sucess thanks :beerjug:
Gaffer tape & cable ties are the usual quick fixes Paul :D
Where did you drop it ?
I'm off to Balderstons this afternoon - have you tried them for the part ?
If you ring Matt & he's got it in I could pick it up for you.
Mick
I dropped mine when the engine stalled halfway through a right turn. I now have the screen sitting slightly to one side. The rear alloy hoop got bent quite badly and the front hoop only slightly.
I have taken a chance and pulled the front screen loop straight. It was out by only a few mm. The GSA rear screen hoop is toast.
But the screen still sits slightly to one side. Careful measuring showed the beak subframe is sitting high at one side. So that will have to be straightened as well.
Put bike on centre stand and sit on the seat. Look at the beak top just ahead of the forks. If one side seem to slope more than the other, the subframe has bent. I have bought a used straight subframe but if I believe if the beak is otherwise straight the problem is likely to be only where the alloy screen frame bolts on to the subframe.
Its a tedious job to measure straighten and refit the beak and frame etc until its sitting correctly.
Mick
Dropped it when i was in Ireland (fell off the side stand)
I've ordered one from Motorwork on Tuesday they are waiting for stock
Balderstons haven't got one either thanks for the offer
Gaffer tape and cable ties it is :D
