Hi,I have just bought a R100 RS 1980 that has been stood for many years.
Thankfully in a dry workshop.
I have now renewed the fuel ines and fitted filters,so hoping to try to run it up later.It spins over and a good spark too.
The front brakes are U/S, poss seals in master cylinder,and poss calipers stuck.
Is it much grief and advantage to change to a handlebar mounted master cylinder? And a step further is it poss to fit the later forks with brembo brakes,or am i best to stick with ATE calipers and under tank master cylinder.
Is it possible to repair the under tank master cylinder?
Any advise would be apreciated. Thanks.
. Lots of stainless bolts,Koni dial a rides.
mutter mutter
