Anyone done this on a GSA? Ratio might be too low![]()
It depends on what you mean.
If you are talking about fitting the 33:11 ratio final drive to the GSA, then it depends on which gearbox you have fitted. The Enduro gearbox, fitted to many GSA's has a lower 1st gear and lower 6th gear than the standard box. It would certainly make the bike sporty, but you would loose out massively at the top end. But if you have a standard gear box fitted then it depends on how you use the bike.
Ian
