r1250gs battery disconnect
fizzer
co durham,england
will the tft screen go back to factory setting reset ,once the battery has been disconnected
many thanks
Not if only disconnected for a few minutes. I suspect that if it’s disconnected for a while it will. Not sure how long.
NO, but make sure you tell the tracker co if you have one fitted, or use the app to show its in "workshop" and for how long
It depends -
Data stored in volatile memory RAM - will be lost once the power is disconnected -
if it is backed up by storage capacitors, then when they are depleted the data will be lost (15- 30 mins approx)
if its in non volatile RAM, then its there permanently ( as its written in such a way it cant be lost)
Also certain data, (mileage) is also sent to various ECU's on the BUS to provide backup incase of tampering --
Say you want to roll 10k off the mileage and fit a kombi with lower miles - the CAS ECU will see the discrepancy and show an error on the Kombi ,
as its expecting to see the same miles in the data sent from the CAS ECU.
