This ^^^^^^
A cautionary tale when bolting all manner of shite to your expensive WC
Gives BMW an easy option to decline a warranty claim
Hope Delboy is listening![]()
Unlikely as he’s stuck on ‘Transmit’....
This ^^^^^^
This ^^^^^^
Then, you make a claim on the warranty of the supplier of said farkles.This ^^^^^^
So they told you that the lever was at fault but they can't tell you that the lever was at fault.
Something isn't adding up.
I should know, I trained as a Barrister - there may be a claim worth pursuing but I won’t pursue it I’d it’ll cost more than the current bill - legal costs and all.
It's quite simple, if A causes B to break, then claim is against A.
Sent from my SM-N950F using Tapatalk
I asked them about pushrod and they basically denied any adjustment in their service catalogue - so pushing it uphill from a dealer perspective. Not really expecting much luck from Motea that would be worth pursuing from a risk / cost perspective, which I’d course is part of their calculation.
That's why there is the small claims court, it comes down to balance of probabilities.Trying to make it stick is the problem
Especially when the fitter is the rider
Good luck with that one
Ultimately whom the Judge judges most truthful.
Have you ? No so don’t be trolling on my post.
AKA Dell The Bell-end strikes again.
Fitting the levers effectively voided the warranty The bike manufacturer says “our stuff is fine, must be the lever”. Then the lever manufacturer says “our levers are fine, lots of people use them with no problem, must be the bike”. Now you’re stuck in the middle, and that’s before they both start saying it was fitted or used incorrectly.
Small claims court isn’t going choose between that lot - been there, done that ... had a replacement engine fitted to a car which promptly blew up. Garage blamed reconditioned engine company, engine company said garage must have fitted it wrong - I ended up paying them both and still had a non functioning car![]()
