R1300gs v KTM 1390
I would not want the auto-clutch as low speed manouvres and really tight alpine bends often require / benefit from moderating the clutch, and a deft bit of letting the clutch in or out at the right time / in a particular situation can be the difference between staying upright or having to pick your bike up and spend a fortune on some bodywork / exhaust can.
The ability for a bike to shift gear automatically does not bother me too much, as long as I can turn it off and change manually,a gear lever being my preference as that is how I have done it for the last 40 years, but the point is I want to get the power delivery to my preference, sometimes low throttle and low revs to gently ride away, but sometimes I enjoy a bloody great handful at low revs and let the Torque be felt and hurl me forward - and not have the bike kick down 3 gears and scream senseless etc.
My desire can change from one gearshit to the next depending on the road, what is in front of me at the time, and although predominantly I change up between 4k and 6k (probably 99% of the time on an open road) it is not always the case, if the bike can "learn" (AI will be next) your "riding style" it could probably get pretty close to changing as you do - just without the "whims" some of us have - and that is where a manual override comes in.
Like adaptive cruise, I can see auto-box being best for heavier traffic and commuting journeys predominantly and I would use it for that if available and almost certainly turn it of on nice twisties, an back on maybe if I was feeling knackered.
When I think of my touring I can see it being in Auto for the ~150 miles of almost exclusively dual carriageway and motorway miles to the Tunnel, and the 2-4 hours I typically spend clearing the clutter of Northern France after leaving the train, before turning it off for the X-country back roads that follow, but it may stay on here and there in "cruising" / "touring" mode, before being firmly ignored once in the Ardennes / Vosges / Black Forest / Alps / Pyrenees until the return journey.
My biggest put-off (apart from the cost of the bikes) is the additional shit to go wrong, all I had in ~25k on my 1190 was issues with error codes and after a service some of the clock display not working. On my 1290 I have replaced a fuel sender (they all do that sir) as well as a couple of error codes, one due to the battery getting a bit past it and causing an error on startup (needing dealer reset) and once when I turned the bike off mid way through a suspension adjustment and confused it - another trip to the dealer....
...and most recently a "brake switch failure" - which was a false alarm, not sure quite how the logic works as the switch was operating fine, had a mate behind me all day with the error coming and going and always confirmed the brake light was working, post replacement the old switch tested fine on a meter, even with much flexing of the cable and trying to get a failure situation, maybe the resistance in the wires increased a few % in the 7 years since new and the over-sensitive self-test system was the real issue....
....and this is the problem, with each new feature there is a host of electronics, sensors, solonoids, wiring all waiting to age a little, deteriorate slightly - or totally fail, the latter is probably easy enough to diagnose, but potentially expensive to fox, but some codes do not give an accurate report to the computer and you end up paying for a dealer to start randomly fitting sensors, switches, ECU's and wiring looms in a bid to fix a fault - all at your expense.
Now if KTM / BMW offered a bike with a traditional key, basic cruise (it is handy, and with fly-by-wire throttles just a few extra lines of computer code) basic ABS (no IMU to fuck up one day) no TC - I can use my right wrist and restraint thank you, manual suspension - which can easily be services or replaced with high quality fully rebuildeable conventional kit for a fraction of the cost, basic display - maybe some LCD segment like the 1190 clocks, but not the fucking laptops they fit now (and thieves love) - I can even check my stop lights work before / after each ride - in 40 years of riding I have never had a brake switch fail until this one did not fail but needed replacing anyway despite being fine, and without the additonal shift-cam and auto-boxes to go wrong I can see a very reliable machine if it was stripped of all that shit.
Basically go back about 10-15 years with the tech, knock £3k off the price and I am in, I was really keen on the CB1000GT until I heard it had semi-active suspension, until then I was half way to justifying one.
I'm pretty happy with what is being offered in the ASA option - after disliking it intently to begin with I came to realise that the auto option is smother than me around town and the quick shift option is much better than on a non ASA bike.
The only question I've not tested (I own a standard GS1300 non ASA) is what you're discussing above, creeping round a very tight mountain hairpin with an adverse camber and a lorry coming the other way - for example.
My preferred technique is to use Enduro and feather the clutch as much as I like / need to.
I'd love to hear from someone who's used it (ASA or alternatives) in these conditions - not fast knee down corners but slow technically challenging corners, where clutch control would seem essential.
Throw in some added weight in the panniers / or a pillion and some rain or loose grit in the mid corner for good measure.
I've not ridden BMW's auto box but have owned a couple Honda's with DCT and my comments are based on them. You're quite correct that being able to feather the clutch is useful, if not critical, and in those instances I wished for a clutch lever. Short of that, the best alternative with an automatic is to have extremely smooth engagement between disengaged and 1st gear engaged, and Honda have done that extraordinarily well with their DCT. This along with using just a little back brake gives almost the same effect as feathering a clutch. I find it interesting how Honda can map the fueling to be so smooth off idle on their DCT bikes yet make on-off-on throttling so jerky on many of their manual equipped motorcycles.
Of course this is exactly what manual mode gives you. The exceptions to this is it won't let you do something that will harm the bike like letting you hold 5th gear at 10mph it'll downshift probably to 2nd. And as you come to a stop it'll disengage and drop to 1st. When I picked up my first DCT (1000 Africa Twin) I figured I'd want the optional (expensive) foot lever that I could use to shift manually but actually changed my mind on the ride home. The forefinger upshift and thump downshift buttons are precisely at the natural spot to use either sitting or standing on the pegs.
The same with paddle shifters, my truck has a ZF automatic with paddle shift right behind the steering wheel and my car is a traditional manual. I wouldn't want the truck's paddle shifters down on the console where a manual shifter would be, they're just easier to use and more natural at the steering wheel.
I don't see how an automatic could learn exactly how you want it to shift w/o being able to see ahead what you see? As you slow down it doesn't know whether it's for a light that's now turned green or a hairpin turn coming up. The automatic program does do a pretty good job keeping you in the right gear most of the time, just like the better auto-boxes in many cars. But yes the override function being able to manually shift it in auto mode for that upcoming corner then let it take back over as you power through reverting back to auto mode is a delightful compromise.
Amen!
I probably I posted my R1300GS purchase before but wanted a 2026 base model which cost $22K here and came about as you described above other than I believe BWM encumbered even it with a fob. But no radar braking, no pacing the car in front just traditional cruise, no active or up and down suspension, electrified luggage mounts, etc. The only one I could find was across the country in Arizona. Dealers around here said they never ordered base models because everyone wants the Premium Package and up. And ordering one will likely take 4 months.
My dealer said he would sell me a 2025, with a bunch of added stuff I don't want, at discount so being impulsive I bought it. It's a nice motorcycle but in retrospect I think I'd be happier had I ordered a base model.
How do you know the statements you claim ?
Have you ridden a KTM 1390 Evo auto or a BMW R1300 GS ASA auto ?
Having put 3.5k on my SAS Evo, I love the auto box.But I ride it mainly in manual mode, using the buttons up and down.I've even removed the foot shift lever from the bike.
As its less unsettling to change by buttons imho.
The KTM system is very flexible, you have two choices for the auto box to run in re the shift changes, you can totally disable the throttle blip and kick down with the throttle (which court me out a couple of times)
Why do I use manual mode, because I can tell the bike when I want to change up or down and you can even come to a stop in fourth and it automatically cogs down the box for you if you forget.
Having just come back from the Spanish Pyrenees the manual mode in the mountains turn this bike into an absolute blast on the hairpins.Like the oil/air cooled GS it pops and farts like a good un on downshifts.
Watch the launch reviews of the Tracer AMT on youtube and all the journos loved that in manual mode.The SAS is the same but with an absolute beast of an engine.
Go try one you might like it or might not.? but give it a time and a chance.
Can we go back to KTM v BMW and not auto v manual please. Interested in the first but not the second.
