Perfect, thanks. Enjoying this.
Shocks are approx 30 mm longer, will sag a little with rider.Have you put longer rear shocks on? Is the standard swing arm and driveshaft OK at a greater range of travel? I can see that you've trimmed the brackets at the sides of the frame. Looking good so far.
Sent from my SM-S901B using Tapatalk
You can fit an adjustable linkage to raise the gear lever,Couple of hours in the garage this afternoon, clutch and gearbox fitted, fitted footrests and gear-lever , I’m thinking the footrests are a little high so I’ll have a think about View attachment 288556repositioning.
The footrests are standard R65, I machined the rubber hexagon bars that the rubbers fit on to accept KTM footrests.You can fit an adjustable linkage to raise the gear lever,
Or I’ve some low g/s Gs ones that may fit the bill better,I’ve had a good look at your photos but can’t make out the footrest fittings well enough to see if they’d fit
Grab a photo when you can
No worries Mike,I’ll try it as it is and modify if I need to.Can’t see the ones I have fitting those mounts
A few more photos.A little more progress, New brake master cylinder, hand guards, heated grips ,crash bars, pannier rails, nearly ready for the rewire, I’m using a PDM60 power distribution unit, so the wiring will be simplified, I’m using the original switchgear.
That just looks lovelyOut in the sun while I service a mates 955 Tiger, I’m really pleased with the choice of frame and subframe colours,tank will be away for paint in a couple of weeks, BMW Alpine White with Red and Blue panels from the R80gs.
