Having a problem with the display on my 1150.
Clock and gear indicator are always ok but after refuelling the fuel display reads empty and the oil temp reads low. When the tank level gets down to 1/2 the display comes back.
I've checked the RID drain hole and the connection to the tank RHS as suggested in other threads. No HID conversion fitted.
The problem has only occured since the fuel pump was replaced at my local dealer so I guess I need to take it back there but just wondered if anyone can suggest anything else to check before I do. Cheers.
