The GSA, when fully loaded, will do that. It will also get its front wheel in the air, when given the beans. The extra weight on the back compresses the rear suspension, lifting the front wheel to skim the ground or fly above it. The rest is simple physics. It's not unusual.
Start with the basics. Are your tyres in good shape and set at the correct pressures? If so, good. If not, deal with accordingly.
Have you had the bike from new? If no, then I might hazard a guess you have no idea what settings previous owners had dialled in or indeed what state the suspension is in. Start from setting the bike back to its standard settings, see owner's manual for details.
What does the suspension feel like now? Crap? Your suspension either needs a good service or replacing.
Does it feel OK? That's good. Now it's just a matter of setting the suspension and tyre pressures to deal with the extra weight. See owner's manual for details.
Any better?
Yes? Job done.
No? Your suspension either needs a good service or replacing.
My suspension started to deteriorate quite markedly at about the 24,000 mile mark, but I toughed it out. The shimmies and shakes / wheel lifting I lived with, in exchange for some fun. At 32 odd thousand the Ohlins went on, front and back. Great kit.
PS One good tip. If it gets bad..... don't slam the front brake on, particularly if the front wheel is in the air. All sorts of interesting things
will happen, when the tyre bites. The shakes are probably not as bad as you think. Try an SP1 for the full effect
