elbowsg450x Guest Feb 7, 2010 #1 what size is the standard chain on the 450? had to give my split link away yesterday so need to buy a new one. cheers
Greg Masters 'Don't mess with me' Member Moderator Moderator Joined Jun 25, 2002 Messages 27,508 Reaction score 3,310 Location Middle England Feb 7, 2010 #2 Spilt links are NOT universal! For a 520 chain, consider: Pin diameter - they vary - although 5.2mm is quite common Pin length - an O or X ring chain is wider than a basic chain Side plate thickness also varies Pitch and roller diameter are pretty standard though. See here Greg
elbowsg450x Guest Feb 7, 2010 #3 i just want to know the size of the standard chain so i can buy a replacement spare split link. im not renewing the chain etc
Greg Masters 'Don't mess with me' Member Moderator Moderator Joined Jun 25, 2002 Messages 27,508 Reaction score 3,310 Location Middle England Feb 7, 2010 #4 elbowsg450x said: i just want to know the size of the standard chain so i can buy a replacement spare split link. im not renewing the chain etc Click to expand... What brand is it? The maker's name is probably stamped on the sideplates. Greg
Sammo Registered user Joined Nov 1, 2008 Messages 122 Reaction score 0 Location Northampton Feb 7, 2010 #5 Just get some from your local dealer, they are only about £3 each, i didn't check and got some 520 links from another bike shop and when i came to fit one , the pins were too short.
elbowsg450x Guest Feb 7, 2010 #6 if the link doesnt have o rings they are thinner so wont fit an o ring chain i bought a 520 renthal f3 link which should fit
